welshlad73
Running problems G60
Hi guys, just thought i'd post something a bit odd with my G60.
I'm in the process of getting my car back on the, purchased a 68mm pulley and chip a few years back.Both installed and runs fines for a while, then it over fuels on cylinders 3 + 4. Causing the car to misfire and poor starting. I removed the tuned chip and installed the original, now the car wont start. No spark, i've checked the files on the chips and there seems to a section of the memory missing. Bare in mind these chips are uv erasable only. Very strange, i wonder if anyone has come across this before????
Edited by welshlad73
Problem solved, my Co was reading 12% on idle, gas tester and a few adjustments makes her run pretty good.
Using the tuned chip, still no success with original.
