vagingit.co.uk 0 Posted January 3, 2012 Couple of parts Im after for my G60 turbo build I need a lambda probe - must be a 4 pin one A brake fluid/clutch reservoir with cap And, I need a couple of brackets from the gearbox: The one at the front of the box that the gearshift cables clip onto, and then I also need the bracket that sits to the left of the rear of the gearbox I will tray and elaborate on the gearbox brackets if I can edit a picture of one Quote Share this post Link to post Share on other sites
mimjed 0 Posted January 3, 2012 Think I've got the reservoir and a cap. Give us a yell if someone can't do the whole shabang for you. Quote Share this post Link to post Share on other sites
rodmax 0 Posted January 3, 2012 Hi. i have the brkts,i think you need, is it an abs or non abs res you need let me know rod Quote Share this post Link to post Share on other sites
