vagingit.co.uk
G60 lambda probe,gearbox parts & brake reservoir
Couple of parts Im after for my G60 turbo build
I need a lambda probe - must be a 4 pin one
A brake fluid/clutch reservoir with cap
And, I need a couple of brackets from the gearbox:
The one at the front of the box that the gearshift cables clip onto, and then I also need the bracket that sits to the left of the rear of the gearbox
I will tray and elaborate on the gearbox brackets if I can edit a picture of one
Think I've got the reservoir and a cap. Give us a yell if someone can't do the whole shabang for you.
Hi. i have the brkts,i think you need, is it an abs or non abs res you need
let me know rod
