scottgroovez
Jabbasport G-Lader
Hi Guys,
I've got a G-lader which has been to Jabbasport before I bought the car. On it it has 'JS027 - R' stamped on it. Can anyone tell me if this would relate to the type of work carried out (particulary the 'R')
Cheers
Scott
Alright Chap
I ve dug out my reciepts for jabba sport and found my one for the rebuild I had on my charger and the serial number is JS 531- S4 now I'm guesing here but think I will be correct in saying that the last digit or 2 digits of the serial number are the type of rebuild you've had, for instance mine was a stage 4 rebuild so yours would have been the R1 conversion represented by the R at the end of the serial number. When you bought the car didn't it come with any service history surely the rebuild reciept would be in there and that would tell you the type of rebuild its had on it. Hope this helps you in your quest for knowledge!!!
corradog60 is correct s4 is stage 4 and r is rebuild does it look like its had any porting on the exhaust of the charger as this is one of the things jabba do when they carry out there stage 4 work
i would say that you charger is a very early jabba one as we had one in the other day which was on js637s4
how many miles has this charger done since the rebuild??
