jamminvr6storm
Late Spec Centre Console
I have one but it has a tab broken where the heater controls are attached. Don't know if this is any use to you? Can put up pic if interested.
Had a close look at it there. There is a very slight crack at the top left of the radio slot. You can't really see it unless you flex the trim. Wouldn't be noticable at all when fitted. Just letting you know. £20 posted if its any use to you. Pic:
Lol. I could see the crack on the pic just cant see if it goes all the way across? i.e. is it actually split in two or is it just a crack.
The one I have at the moment is split so not much point buying another one in the same condition fella.
