Si Watson 10 Posted March 6, 2012 as above i'm after switches for the electric seat (not the heater switch) i have cash waiting switch is this one in pic if anyone can help i love ya forever ;) [ATTACH=CONFIG]54437[/ATTACH] Quote Share this post Link to post Share on other sites
Chrisvw419 0 Posted March 6, 2012 If you're not too fusy, early electric window switches fit and do the job perfectly. Maybe an easier and cheaper find than used or arz-tuning prices for new ones. ---------- Post added at 7:59 PM ---------- Previous post was at 7:51 PM ---------- Two on this thread for a tenner. http://the-corrado.net/showthread.php?63901-Many-parts-badges-grills-headlight-covers-fog-lights-rear-lights-switches-etc Quote Share this post Link to post Share on other sites
GusPW 0 Posted March 6, 2012 I thought only recarros had these, if so then you'll be lucky to find second hand switches and new ones are about 50 quid each! If they've just stopped working then try taking them apart and cleaning the contacts. Use a bit of wet and dry sandpaper and make the little contact disks shiny again then spray the whole lot with contact cleaner. Did this with all mine and they've been fine ever since. ---------- Post added at 11:29 PM ---------- Previous post was at 11:22 PM ---------- I thought only recarros had these, if so then you'll be lucky to find second hand switches and new ones are about 50 quid each! If they've just stopped working then try taking them apart and cleaning the contacts. Use a bit of wet and dry sandpaper and make the little contact disks shiny again then spray the whole lot with contact cleaner. Did this with all mine and they've been fine ever since. Quote Share this post Link to post Share on other sites
