SLC_43
R32 clutch with 02a tranny?
Wondering if anyone knows if the R32 clutch assembly will work with an 02a trans (do the splines match?). Looking into a 24v swap for my corrado....
Won't work in an 02A.
R32 clutch is bigger diameter (240mm IIRC, 02A is 210mm?), concentric release bearing and no friction plate shock absorbers as they are in the Dual Mass flywheel in the 32.
