aposegil
vr running issues
hello all
i need some advice.
This weekend got a new maf and lambda as both old and in vagcom lambda was coming up
but still having a issue. with everything pluged in the car idles very high lumpy crap and overfueling still
If i unplug the ISV revs drop runs lumpy
If I unplug the TPS it tries to find a level idles nicely
If I unplug the maf again tries to find it idle
but if I unplug the lambda it idles perfectly
in all situations the car drives badly doesn't want to rev and lumpy.
one thing we found the lamda casing been crushed (i think from when they did the water pump) so contacts in side where touching. Not sure if this is any good info.
So what i need to know is firstly does anyone have any ideas? and does anyone have the vagcom values for all sensors at idle and thru the revs
Its a 1992 vr6 with the 6 pin MAF and coilpack.
thank you in advance
Ok.... Is it the same problem as before?
Have you erased the faults after replacing the bits? If so have you checked after running?
If everything checks out fine and the only fault code you get after driving is something like lambda regulation, then I would clean the isv just to make shure and the a full ecu reset to make all the lambda values adapt.. Thats most likely your problem
before changing was running crap and high idle once in a while
codes have been cleared and battery was left off the car for a hour and still problems.
I got a feeling that the lambda casing being crushed must have shorted something in the ecu
Well when ever you disconect the battery the car will run like crap... Thats not a ecu reset.
Follow rw1's wiki page for the FULL ecu reset
do you have a link as i keep find reset but not for vr
Hey Alex... Long time no see. Hope you are keeping well mate :)
yeah long time, i still log in once in a while to read up :)
it just my brother corrado playing up :( he been getting very annoyed and Ive been to busy to sort it out. So being a long weekend trying to sort it out lol
how you been?
well quick update
did rw1 ecu reset which made it run a lot or the running issues but still had some misfire issues.
me thinking it was a coilpack a mate told me to change the leads and the car now runs perfectly
so thank you for all your help
Good result :) Leads, MAF, coilpack and an ECU reset seem to be the gateway to VR6 happiness :)
you forgot lambda as well ;) yes my brother is very happy now. Loves the corrado again lol.
I remember those love and hate moments with my old c lol
