Topaz2008
OMEX ECU Install Corrado G60
I am just about to start the install of an OMEX ECU on my G60. The wiring, connectors and that sort of stuff is not an issue for me but I have a couple of mechanical questions.
1. I have to fit a TPS (throttle position sensor) to my throttle body to replace the two switches that are currently used by the standard ECU. Has anyone got any advice on where and how to mount it?
2. I have to fit a 140mm slotted wheel to my crank pulley for the crank position sensor to work with. Has anyone got any ideas on how this can be acheived easliy. The part supplied only has a 20mm hole in the centre.
TPS picture attached.
