VEEDUBBED
Brake fluid problems...
Right guys,
i've got a problem with brake fluid being forced up and out of the plastic fluid resovoir on top of the ABS block.
Turn the ignition on for a bit and the fluid level drops to the MAX mark courtesy of the ABS's motor but as my 'raddo is seldom used i notice that after a few days the level has risen to the top! sometimes even pushed out the cap..
I've changed the black pressure sphere with a used item but now it's even worse.
What's up? anyone else had this problem?
