Turborado
Which engine mounts do you recommend
I have a 1.8t conversion in my rado and unfortunately the engine mounts are on their way out. So the questions im asking are; are the standard leon engine mounts the right ones because of the conversion? and secondly if i were to go the vibratechnics route which do you recommend? (car is a daily driver which never see's a track) thanx
I had Vibratechnics fast road mounts on my mk2 9a golf one of my better investments mines wasa everyday driver:thumbleft:
ANNE
It depends how the engine is mounted as to which mounts you need, usually the corrado mounts are used, but sometimes people weld the 1.8t donor car mounts to the chassis legs.
Which mounts you need obviously depends which mounts have been used so check first ;)
