vw_john 10 Posted May 4, 2012 been trying to solve an issue where if you turn the wheel left to right there is about an inch of travel before the steering bites in, are there any bushes I should change in the steering? I have had a new rack on and its not that, so I'm confused. Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted May 4, 2012 Check: Lower ball joints Wheel bearings Inner and outer tie rod joints Geometry Quote Share this post Link to post Share on other sites
vw_john 10 Posted May 5, 2012 Thanks mate, i'll get right on that! Quote Share this post Link to post Share on other sites
daleyboy 0 Posted May 7, 2012 I had woolly steering when i didn't do my rack bolts up tight enough......also check all your subframe bolts which i presume you had off when changing the rack....... Quote Share this post Link to post Share on other sites
