Dodger
the engine is apart, parts on order, am I missing anything?
After removing the head and finding the head gasket was bad, I decided to go ahead and freshen up the rest of the engine. Here is what I am replacing;
piston rings
all gaskets
all seals
MLS metal head gasket
new head bolts
valve stem seals
re-crosshatch the cylinder walls
crank bearings
connecting rod bearings
water pump
timing belt
tensioner
spark plugs (again)
woodruff keys
The head is at the machine shop. The pistons cleaned up rather well and the cylinders walls look great. Am I forgetting to replace anything?
