chrisavr6
need to raise the ride height
need to raise the ride height on my corrado as i cant get it out of the driveway as its so low (without using a wooden ramp ) its fitted with kw v1 coilovers i have the large c spanner is it a straight forward job and do i need to get the tracking and camber reset afterwards thanks
yeh very very straight forward, dont forget to undo the grub scew on the collars first, and i always give the threads a quick clean before i wind the coilovers up or down to make the job easier.
and no need to get the camber/tracking done after
undone grub screw on front strut and cleaned up the threads the adjusting ring moves down the strut easly but when i tried to move it up the strut the spring tension makes it impossible to move should i release the top nut on strut to ease the tension or use spring compressors? thanks
