STORM 2
oil filter housing WIRING question
According to Bentley, there are 2 oil pressure switches on the top of the oil filter housing on the VR. Facing the car, the switch on the left is a yellow wire and the one on the right is a blue wire.
Which one is the high pressure switch (1.4bar) and which one is the low (0.3 bar)?
I need to replace the blue wired sensor on the right as you face the car - which pressure switch is this one - the low pressure or the high pressure one?
Are the sensors themselves coloured? And if so, do they match their wires or is this another point of confusion?
cheers
Where's the Prof, I mean RW1, when you need him? ;-)
Edited by STORM 2
