CVR6-T-HD 0 Posted June 3, 2012 VR6 | Black | Suffolk Price: £7750Description: VR6-Turbo | Black | Suffolk, United Kingdom Price: £7750 ONODescription: Almost a Classic. Absolutely beautiful Corrado. I've spent hundreds of hours and over 11K pounds in the past 7 years refining this beast. I'm ready to move on to another platform. Serious buyers please. 90% of the engine bay has been replaced with new or upgraded alternates. Engine was rebuilt at 99K miles. Listed below is the bulk of it: Borla 2.5" Cat-back Exhaust High Flow Catalytic Converter 5 pc. Polyurethane Motor Mounts Head Stud Kit, ARP Autotech 10lb Flywheel Spec Clutch Kit, Stage II+ (395 ft/lbs) Inconel Turbo Exhaust Manifold Timing Chain Kit, Dual Chain rebuilt w/upgraded tensioners Peloquin Planetary LSD Piston Ring Set, 81mm (Honed out cylinders by hand) Rod Bearing Set (OEM) Rod Bolt Set, Complete (Performance) Suspension Rebuild Kit w/ ZF Tie Rod (HD) Koni Sport Coilovers, adjustable Radiator (OEM) Slimline radiator fans Custom Stealth Racing Mapping Garrett GT35 Turbo w/3" Piping (2012) Tial Sport 38mm Waste Gate SSQ Blow Off Valve Profec B Spec II Boost Controller DDI Gauges with steel rings/DDI Reverse Lighting Kit (Red) Neuspeed Power Pulleys (set of 3) Intercooler Custom Piping re-done (2012) Optima Battery Deep Cycle Full Body Kit RS Style Neuspeed Spark 8mm Plug Wires Iridium Spark Plugs Samco Complete Coolant Hoses 30 lb Fuel Injectors Rear/Front Neuspeed anti-sway bars Oil Pressure/Boost Gauges O2 Wideband Sensor and AEM Gauge Grounding Kit 8.6:1 Compression Head Spacer 258 deg Turbo Cams Ported polished Throttle Body Shortrunner Intake Manifold Oil Cooler Kit Custom Speaker System and woofer boxes in fiberglass. Fuel/Air Gauge/Boost Gauge/Oil Press New HID Kit 6000K The only faults it has are a deteriorated sunroof liner which will bind the cloth if opened. The sunroof works perfectly but I just use the tilt for this reason. The rest is just wear and tear to the leather, small chips/couple of small rust spots. Must see to appreciate. Projects I'm still working on are drilling hole for oil pressure sensor (gauge), short shifter kit, and finishing my very unique woofer boxes..let me know and I'll send pics of that. Just needs to be sanded a bit more and vinyl cloth wrapped like my door speakers. The vechicle is located in Suffolk, United Kingdom. Call for more pics, details or viewing. Quote Share this post Link to post Share on other sites
