classic 0 Posted June 19, 2012 Hello, I'm after a Nearside / passenger side Driveshaft For my corrado, its H reg and doesnt have ABS, Looking for a good condition one with both cv boots in good condition. Looking to spend up to £50 posted. Thanks alot, Vince Quote Share this post Link to post Share on other sites
rodmax 0 Posted June 19, 2012 Hi i have two n/s shafts, i'll see which is the best and get back to you Thanks Rod Quote Share this post Link to post Share on other sites
boost monkey 0 Posted June 20, 2012 i don't think there are ABS and non-ABS spec driveshafts. You could even take some from a mk2 golf if you needed, they're all the same AFAIK. Quote Share this post Link to post Share on other sites
classic 0 Posted June 20, 2012 ah ok brilliant, i didn't know if the abs ones had a pickup ring on them that would affect the length / fitting of the outer cv joint. cheers! Quote Share this post Link to post Share on other sites
boost monkey 0 Posted June 21, 2012 the abs ring sits inside the disc :-) Quote Share this post Link to post Share on other sites
