lgs 10 Posted June 21, 2012 (edited) Hi all just got my new rims today bbs but I have a problem they don't fit the front is 7.5x 17 with 205x40 And the back are 8.5 x17 with 205x 40 the rims are 17in with er35 the front need a 20mm spacer and the Back 10mm to clear the front also rubs on the calliper dose any one what size will fit with no Spacers I can live with the back spacer but I need to do something with the front, Regards liam Edited June 22, 2012 by lgs Quote Share this post Link to post Share on other sites
VAG-hag 0 Posted June 22, 2012 something does'nt add up here mate as et35 & 17x7.5 should go straight on, no spacing required! Are you 100% on the offset etc?? Quote Share this post Link to post Share on other sites
lgs 10 Posted June 22, 2012 (edited) Yes the et is 35 when you fit the front it hits the calliper you need about 20mm to clear the wheels are bbs rs,s the speed line wheels I have on have a et of 45 dose make a differents Edited June 22, 2012 by lgs Quote Share this post Link to post Share on other sites
C5 OEM 0 Posted June 22, 2012 whats the model number on the rs`s Quote Share this post Link to post Share on other sites
lgs 10 Posted June 23, 2012 hi will look on monday Quote Share this post Link to post Share on other sites
