hipcity
dash thermostat
Corrado dash thermostat to measure external temperature is reading high 20’s when its only 10 outside?
I should mention that the radiator motor fan and spoiler motor are both not working correctly
Corrado 93 2L 16v
i found mine usually slipped out of its mount under the bumper and was hanging loose as a lot of people pointed out when i parked up :/ perhaps yours is reading a bit of engine heat or something.
does it still read high when the engine is cold?
it might be faulty. Not sure where to get them from - if everything else on the MFA works right you could try and replace it. Ebay might have some.
thanks for those pictures
---------- Post added at 9:52 PM ---------- Previous post was at 9:41 PM ----------
Looks to be missing from the lower front grill? Will need to hoke around to see if i can find it :-)
