tentonhammer 10 Posted July 4, 2012 Does anybody have fuse and relay position diagrams for a C 92 16V 2.0? I had them a while back but can't seem to find mine anywhere! Cheers, Ten Ton Quote Share this post Link to post Share on other sites
eugopnosaj 0 Posted July 5, 2012 Check out page 13, it gives you a relay diagram and the fuse numbers and ratings, it doesnt tell you exactly which fuse is for what on this page but if you go through the pages you can work it out. Also this is for a VR6 mainly but it is mostly the same Corrado92.pdf Quote Share this post Link to post Share on other sites
tentonhammer 10 Posted July 6, 2012 Not a problem I can work out which fuses are for what, it was the relay positions I needed mainly. Cheers! Quote Share this post Link to post Share on other sites
