Hymorrill 10 Posted July 5, 2012 Hello. I just got a 93 corrado slc. I bought it with 150k and everything is up to snuff minus my passenger door handle and this current issue. Yesterday I put new break pads on and while lifting the driver side I noticed the front wheel went very loosely from a cambered position to straight. I figured it must be the coilovered since I have not worked with coilovered before. After putting the new pads and fitting the tire with some tightness before dropping it, I noticed the wheel was very loose. I thought it mIght be because the caliper had not come back to rest but now I am getting a noise from the Pads rubbing. Anyone know what I should do? Quote Share this post Link to post Share on other sites
carrots 1 Posted July 5, 2012 sounds like it could be a number of things,wheel bearing,track rod end,ball joint,bolts loose in bottom of coilover Quote Share this post Link to post Share on other sites
VW_OwneR_85 1 Posted July 5, 2012 jack it up on that side so the wheel is off the ground, grab the wheel at both sides {i.e at 9 oclock and 3 oclock positions} and rock it back and forth and try to identify where the play/movemnt is comming from, you might want to get someone else to do that while you look for the play. Quote Share this post Link to post Share on other sites
Supercharged 2 Posted July 5, 2012 Hub nut is the pads are rubbing! Should be able to get to this without taking a wheel off to check it - through the centre cap Quote Share this post Link to post Share on other sites
Hymorrill 10 Posted July 6, 2012 Hub but was loose. I tightened it down as far as I could go without stripping it and checked and the tire is still wobbly. Horizontal and vertical. The axle also shakes a little bit. Mind yu this is only the driver side. So I believe it is most likely the ball joint and or bearing. Where do you guys order parts from? Quote Share this post Link to post Share on other sites
dochy 0 Posted July 6, 2012 hub nuts shouldnt be that tight.too tight and u will destroy the bearings!! Quote Share this post Link to post Share on other sites
