thegrouch
Right Rocker Wrong?!
Bit of a question here, during my engine rebuild/refurb, I picked up a metal rocker(cam) cover which was advertised as mk3 or corrado fitment. When I've gone to fit it though, it seems that although it does fit, it a) has a flat gasket surface whereas the original corrado plastic 1 has a recess for the gasket to sit in, b) doesn't have anywhere for the fuel line clips to go and c) has different fixings although this doesn't really matter as any 6mm fixings should do the trick. So what I need to know is, will a mk3 vr6 gasket fit (sitting between two flat mating surfaces) or can you get a genuine metal corrado cover, one which will use all the original fixings, clips and gasket as I have a bag full of brand new oem fixings and gaskets which weren't cheap! Sorry for the long winded question and thanks in advance for the help guys!
