Pete
jerky help needed please!
Hi guys, car has developed the annoying on/off throttle jerk that seems to be common.
Not being much of a mechanic I've booked into garage for Friday but rather than paying lots of time for diagnosis I was thinking about putting a list together of the common causes.
Doing a search listed dry solder on fuel pump, and maf plug, but is there anything else I can tell him to do in the first instance??
Cheers!
Im having this issue at the moment - have adjusted my throttle dampner as it wasnt doing anything, helped a little but problem still there.
Am going to replace engine mounts next as there seems to be a fair ammount of movement there.
im going to do a search for 'dry solder' now tho! :scratch:
Got this issue, was told it will be the damper. Not tried it yet though. Also mine has been scanned and has no faults. Will be watching this thread.
  VAG-hag said:
you need jerky help?? loads a sites out there to help you with this!! :lol:
DAM YOU VAG HAG! you beat me too it! found you a link that might help though mate HERE!
Was scanned when in for the MOT and all is well.
The throttle sensor seemed OK when I was looking at it but it'll be on the list to check.
Anyone know where the dry solder joints for fuel pump may be???
update:
have changed the front and rear engine mounts - but not gearbox one yet - and problem still remains.
will try something else.
