everard90 10 Posted August 19, 2012 hi changing my g60 engine for a g60 witch has been rebuilt and ported and polished with a stage 2 charger standered pully and cosworth stage 2 injectors will the ECU be chipped ? also it is out of a h reg with no ABS mine is a g reg with abs will the ECU work with mine Quote Share this post Link to post Share on other sites
floppyman 0 Posted August 19, 2012 The ecu will most likely be chipped... But it must be a plug and play chip. Remove it from the ecu and install it on yours... :sly: Quote Share this post Link to post Share on other sites
