dubnut
intermittent starting
hi all
i have came into possession of a satin siver valver
its failed mot on emissions..so I've replaced cat n
lambda..
anyway it doesn't start every time ?
connect bat
turn key....engine turns doesn't fire...turn off
wait ten secs ...turn key...fires first time.
it does this consistently...turn it off and try to
start and it won't...turn off...wait ...turn on and
fires..
im led to believe and can see evidence of coil..leads...
plugs...metering head...all being replaced
when it starts it runs fine although it did bog down
and had no power last time i drove it...took water temp sensor
off and it ran again...tested sensor and seems fine
any ideas anyone. i am searching the forum as you read this
want it on the road as a nurse ran into my blackberry as
i stopped for a ambulance !!!
Been having similar issue.
Is the engine trying to turn over?
Have a listen at the rear for any whine from the fuel pump, if so consider new one as the pump might not be priming the fuel lines ready for the first attempt. The pump should be pretty much silent.
Other things could be blocked injector, and you can get them cleaned, but to be honest that would probably be ore random and from what you describe it's doing it consistently. Does it idle smooth or lumpy? A rough idle is a sign of injector issues.
If it were stuff like coils, plugs and leads etc it wouldn't be so predectable at the second attempt so I would look at fuelling first.
fuel pump under car whirrs for a couple of secs
everytime i turn the key then is silent..
I've swapped temp sensor for known good
no difference...
gonna swap the coil over...got brand new dibby and
arm
stuck !
---------- Post added at 5:50 PM ---------- Previous post was at 5:49 PM ----------
and leads and plugs?
When you turn the key do the lights on the dash go out, battery oil etc... if so i reckon Ignition switch mate mine wont fire either , i've just ordered one off the bay £5 ish
