ryanmac 10 Posted September 1, 2012 Hi all I am about to complete my vr6 and use it for track days or commutes into work once or twice a month along some nice fastish a roads. I am looking for some info from anybody that uses there car for track days as I need to set up my suspension. The car runs 205/40/17 wheels due to the brakes plus it is fully poly-bushed on the rear with poly bushes on the front of the wishbones and r32 bushes on the rear.It also runs KW coil-overs that have been adjusted down pretty far but still allowing the drive shafts to run horizontal to the ground. The rear will also be fitted with an eibach camber kit and has a rear strut brace with strut braces on the front both upper and lower. It will eventually run the adjustable top mounts I have sitting. My question is what do people run with regards to camber and castor on the front and rear of there cars... Cheers Ryan Quote Share this post Link to post Share on other sites
LRWMotorsport 10 Posted September 3, 2012 Drop me a line and I'll forward you a set-up sheet as a start point. Quote Share this post Link to post Share on other sites
ryanmac 10 Posted September 4, 2012 cheers for the reply. PM sent Quote Share this post Link to post Share on other sites
