bigbaz 10 Posted September 5, 2012 hi ive just bought a 1991 g60 as a project the lad i bought it of said the battery keeps going flat it runs fine but about a minute or so after you switch it off with the keys removed the fuel pump starts and only stops if you switch the key back on any idea's cheers Quote Share this post Link to post Share on other sites
kerrly 0 Posted September 5, 2012 This sounds like the sensor which is on the drivers side of the fuel rail, it is a single pin brown wire. Check that it is connected and if it is not cover the end with some insulation tape to stop it earthing and see what happens. Quote Share this post Link to post Share on other sites
bigbaz 10 Posted September 6, 2012 cheers for that will have a look Quote Share this post Link to post Share on other sites
G60Luke 0 Posted September 6, 2012 Had this on mine, think i had to change a relay? . . . . . Quote Share this post Link to post Share on other sites
