andi spencer
Top mounting bolt front suspension
Top mount bolt on the front suspension strut. How do you losen the bolt? I can see its got a Allen key screw which runs down inbetween the bolt which when turned just spins the strut underneath. Any clues fellow corrado owners.
Hold the allen key and undo nut - either with a swan-neck spanner, through socket or lambda socket if it's 22mm (some are 21mm)
Edited by Supercharged
