VW_OwneR_85 2 Posted October 11, 2012 guys picked up a mk2 golf converted to 2.0 16v ABF and noticed that theres something missing here, whats this for and whats missing? seems to be sucking in air , havnet driven it properly but otherwise seems to be running fine also anyone know where i can get the flexy hose for the slave cylinder for the 02a gearbox? cant find one anywhere!! Quote Share this post Link to post Share on other sites
Drewie 10 Posted October 13, 2012 That's the ISV on the ABF, if you take off that cover that's got the HT leads pushed into it, you can see it in all it's glory. Think the pipe you're missing goes to the engine breather, iirc. :scratch: Quote Share this post Link to post Share on other sites
Matty-H 10 Posted October 28, 2012 There should be a pipe that comes off it straight to the airbox. Quote Share this post Link to post Share on other sites
VW_OwneR_85 2 Posted October 28, 2012 cheers guys, yea i brought an airbox for it and the connection for it is right there, also found out why it was running ****e Quote Share this post Link to post Share on other sites
Roger Blassberg 0 Posted October 29, 2012 That looks to be caused by a leaking cam cover gasket (the central part) allowing oil into the spark plug recess, and the oil has emulsified. The cure is to replace the gasket, which means taking off the inlet manifold. Best wishes RB Quote Share this post Link to post Share on other sites
