Corradochris16v
Number plate lights not working
Can Anyone help my reg plate lights arnt working I've changed the bulbs and checked the fuse the only thing I haven't done is check the lights with engine running as me engine is in bits would this make a difference?
Take the light out,the wires on the unit are soldered on it. Not very well ! Or mine wasn't ! Most likely it needs re-soldering. If wires are ok,check with multi-meter
Good luck
Ive got the same problem but ive got low voltage going to them not 12v :/ anyone else had this issue ? it was after i changed my rear spoiler aswell
Good luck
I had this exact issue on mine. Simple to fix. Just unscrew the light cover and solder the wires back on.
