elnigel
Radiator cover support bracket from 16v or 8v. Please help!
Hi. My radiator plastic cover is flapping about as the plastic support for it has broken off somewhere in Derbyshire!! I desparately need a replacement bracket if anyone knows where I can find one? It connects from the the fan motor housing vertically to the plastic radiator cover and holds a small hose also.
Thanks!
Sent from my BlackBerry 9320 using Tapatalk
If its the same arm thing i think you're on about i may still have this on my 1.816v breaker. will find out and let you know this weekend if you have no joy.
Andy.
This part was still available from VW when I bought it several years ago, and wasn't a bank busting amount... if a pre-owned one doesn't turn up :)
If you have it that would be great. Could you have a look please?
Thanks!
Nigel
---------- Post added at 8:36 PM ---------- Previous post was at 8:32 PM ----------
Thanks for your advice Jim. Unfortunately I have already been to my local VW TPS and it is now obsolete! That's when I started worrying!
