robo22sri
schrick odb2 and odb1 difference?
As title!
What is the difference between odb1 and odb2 schrick inlets?
I know the TB mounting is different but is the wiring for the controller the same?
Cheers Rob
So the wiring harness under the scuttle is the same?
I am looking at buying a golf vr odb2 but the current golf is odb1
just need to sort out a plate for the TB then :)
The only wire needed from the ECU is an rpm signal, which IIRC, is still the thin green/black wire in the ECU harness. Can't remember the pin number. The Schrick controller then just needs power and ground and that's it.
