jpowell79
Driver's door window scraper seal
I'm looking for the long bit of plastic that runs along the top of the door card by the window...mine has a big crack in it.
Cheers
Should have one of these. Will confirm tomorrow. Are they handed from memory?
I should be able to work it out...
Rams
I am also after the plastic trim (drivers side) that fits internally on the top edge of the door and then the door card fits up against it as mine is partly broken - They are shaped to fit so are definitely handed.
Ian.
