nipper09
engine movement?
hi all
when iam braking theres a clunk feels like theres some sort of movement in the engine !!
any help advice pointers will really be appreciated
cheers paul
Get someone to look at the engine while you slip the clutch in first with handbrake on. And check security of battery!
Likely to be the mounts. Standard are fluid filled which might move, or maybe they are aftermarket polyeurethane which also make clunky creaks when cold. Does the noise go when the car warms up?
