Erny
G60 supercharger exhaust side outer casing
Trying to get hold of one of these if possible, standard or ported if its a decent job.
Thank you
IIRC the charger 'halves' are matched to one another at build, you can replace the inner scroll with a new one as there is tolerance for that.
Agreed Yan, the casings as with all charger parts are matched at point of manufacture, and serial numbered to recognise a set of parts. However, we have successfully replaced damaged casings with salvaged parts, in otherwise good order, and as a result allowed a U/S charger go on to give good service. The key is to replace the damaged casing with one of the same production date. Also one needs to ensure there are no rotational tight spots in the repaired assembled unit. For this reason, at JMR, we keep a stock of used casings to call on as required. With so many chargers suffering from heightened levels of wear, and replacements being so hard to find, this stock is being increasingly called upon as an option.
