brownsoda 10 Posted December 29, 2012 Hey guys, hoping for another set of eyes from across the pond to help out. MY VR6 isn't starting. It's a OBDII motor swapped into my 93 Corrado. I get fuel to the fuel rail, and I have spark, but it won't start. It makes oil pressure and trys to run on starting fluid. I pulled relay 109 the Motronic power relay and jumped its pins and it didn't seem to change anything. Any ideas or any more info you need Ill be watching the thread hoping for help ASAP! Quote Share this post Link to post Share on other sites
science 0 Posted December 29, 2012 Do you have the immobiliser active or has it been removed from the software? Other than that Vag-Com is your friend. Quote Share this post Link to post Share on other sites
dumptyboy 0 Posted December 29, 2012 Stale fuel/gas possibly? Quote Share this post Link to post Share on other sites
brownsoda 10 Posted December 29, 2012 Old gas yes, but i put 7.5 gallons of fresh 91 octane in less than a quarter tank of old gas and added a bottle of octane booster so it should be ignitable I'd reckon. Guess if I pull a plug and its wet that's a sign the gas isn't flammable. I still think its the injectors not firing over them firing bad gas. ---------- Post added at 4:39 PM ---------- Previous post was at 3:58 PM ---------- It's a 98 motor, I don't think there's any immobilizer or anything, I converted the OBDII motor to OBDI (cams, timing bits, timing cover, dizzy, sensors and such.) I'm reaching stumpedness. Quote Share this post Link to post Share on other sites
