nia573 0 Posted January 8, 2013 (edited) Have some handy test leads for sale 1st type are for connecting a multimeter to the fusebox: Draper Expert Fusebox adapter test leads Either for 3mm mini fuse blades or 5mm maxi fuse blades For testing & measuring current straight from the fusebox. Plug the lead directly into fuse socket recess & while being tested the fuse is inserted into the side of the tester housing to maintain circuit protection Avoids the awkward process of pushing test probes into the fuse sockets & making temporary connections Leads are approx 750mm long These are £6.50 each posted 2nd class recorded 2nd are stand alone testers that plug into fusebox directly to measure current drain (Ideal if you don’t have a multimeter) Draper 3mm mini fuse or 5 mm maxi fuse Blade Automotive tester Expert Quality, for rapid and accurate amperage testing. 12-48V/20A AC/DC measuring range. Liquid Crystal Display screen shows readings. Plugs directly into fuse socket recess. Supplied with cable 750mm long. Uses 12V-A23 battery (supplied). These are £15.50 posted each 2nd class recorded Expert Spark Plug Thread Repair and Restoring Tool M14 X 1.25mm Expert Quality, for the repair of spark plug threads. Allows thread repair from the bottom (not the top) so that swarf & debris wont fall back into the threaded hole, as it would with a standard tap Insert the tool through the thread Expand until it is located Carefully wind out tool to reform damaged thread Satin chrome plated tool steel hardened and tempered £15 posted 2nd class recorded All items are new & unused Zag High top Toolbox 14.5” 405mm long With tote tray inside Hardly used Bit dusty on the outside £12 posted Some top quality gloves These are meant for horticultural/gardening use but are v good quality & could be used for other things Soft Touch Gloves Gents size Leather & Nylon Backs with Velcro fastening cuff £12 posted Dry TouchGloves Ladies size Treated soft leather £12.00 Posted Winter Touch Gloves Soft leather & Nylon with Thinsulate lining Ladies size £13.00 Posted Mike Bangor N Wales [email protected] Edited January 8, 2013 by nia573 Toolbox & gloves added Quote Share this post Link to post Share on other sites
