chrishill 0 Posted April 25, 2004 While out for a spin with chrisVR6NOS yesterday we were trying to get my MFA to show the extra info, but couldnt get it to work! how do you do it on a 1.8 16v? Quote Share this post Link to post Share on other sites
stevemac 0 Posted April 25, 2004 Only method I know is for the G60 - 1. Start Engine 2. Move the MFA selector to "2" 3. Press and hold the MFA end button (keep holding) 4. Stop engine 5. Start engine 6. Release the MFA end button. As you press the MFA button it will take you through the extra features. I can't remember if my old Scirocco (similar K-Jetronic injection system as the 1.8-16v) had the extra MFA features or not. Quote Share this post Link to post Share on other sites
chrishill 0 Posted April 25, 2004 well it worked 8) erm...what do the numbers represent though? lol Quote Share this post Link to post Share on other sites
stevemac 0 Posted April 25, 2004 http://www.myscirocco.com/scirocco/mfa/ ... fa_02.html http://www.gti-vr6.net/library/electric ... ricks.html About all I could find - HTH Quote Share this post Link to post Share on other sites
Bojmobile 0 Posted April 25, 2004 What exactly does this thread relate to? :? I havent heard anything about the MFA having extra info before - is it useful? Quote Share this post Link to post Share on other sites
phaserno1 0 Posted April 26, 2004 it works, i tryed it on a m8's one.. :D Quote Share this post Link to post Share on other sites
stevemac 0 Posted April 26, 2004 What exactly does this thread relate to? :? I havent heard anything about the MFA having extra info before - is it useful? The extra info is used most commonly for checking the boost pressure on G60's but it shows other things too. Quote Share this post Link to post Share on other sites
Dec 1 Posted April 27, 2004 Just remembered I had some stuff on this hidden somewhere :) For pre 1992 C's the extra MFA functions are: MFA switch, position 1: 1: Engine map code. 2: Country code. 3: Speedo drive ratio. 4: Upper RPM limiter. 5: Lower RPM limiter. 6: Deceleration fuel shutof pressure. 7: Segment test. MFA switch, position2: 1: Test sum of programmed bytes 2: Intake manifold vacuum/pressure. 3: Engine RPM. 4: Momentary fuel consumption. 5: Signal from speed sensor. 6: Oil temp. 7: Ambient temp. Hope its of use to someone!!!!! Quote Share this post Link to post Share on other sites
stevemac 0 Posted April 27, 2004 Hope its of use to someone!!!!! Lots of use m8 - cheers :wink: Quote Share this post Link to post Share on other sites
