johnmac 10 Posted January 20, 2013 Hi all, I was wondering if anyone could help me, my abs light stays on, tried VAG-CO0M (cheap one off ebay, it worked fine with my other corrado and connects to engine codes) but wont link, tried changing the latency setting and nothing, any would be great. Quote Share this post Link to post Share on other sites
nrc 0 Posted January 20, 2013 Check the VAG-COM scanning & help thread for someone near you who could assist with scanning or post your location and see if there's anyone nearby. In my experience it's usually a faulty sensor or poor connection that causes the light to stay on. Also, welcome to the forum! Quote Share this post Link to post Share on other sites
johnmac 10 Posted January 20, 2013 Thanks i, just seems strange no link at all, been seaching for a week or so on here but came up with apart maybe faulty abs ecu. Thank you for the welcome aswell. Quote Share this post Link to post Share on other sites
Supercharged 2 Posted January 20, 2013 Yeah if it connects to the engine codes then it's either a wiring issue or a bad / water damaged ABS ECU Quote Share this post Link to post Share on other sites
johnmac 10 Posted January 20, 2013 Thanks for the help guys ---------- Post added at 6:03 PM ---------- Previous post was at 5:53 PM ---------- Hi all, found 3 relays behind the glove box. 2 with fuses 1 is 179 and the other is 79, the one with out a fuse is 179. the 79 with a fuse has a brown wire broken is this to do with my abs light or is it something else? Quote Share this post Link to post Share on other sites
Supercharged 2 Posted January 20, 2013 Yep - they're your ABS relays... The ECU is behind that panel on the left of the footwell near the door - worth checking the connections to this as well for corrosion Quote Share this post Link to post Share on other sites
johnmac 10 Posted January 20, 2013 I have another abs ecu on its way,the brown wire is in bad nick might have to run a new in, Thanks for help Quote Share this post Link to post Share on other sites
Supercharged 2 Posted January 20, 2013 Should just be an earth - brown always is on VW's... Worth connecting to something to test - maybe stick a fuse on there if it looks burned out incase some current is being fed down there. Quote Share this post Link to post Share on other sites
johnmac 10 Posted January 20, 2013 I will try abit wire the morn and see if it works. Thanks for the help :thumbleft: Quote Share this post Link to post Share on other sites
