Yash 0 Posted January 31, 2013 Ideally 90amp. Thanks Quote Share this post Link to post Share on other sites
carrots 1 Posted January 31, 2013 hi if yours has just stopped charging proper it might be worth buying a brush kit off ebay.mine was only charging 10v,i fitted it and it charges fine again. Quote Share this post Link to post Share on other sites
Yash 0 Posted February 1, 2013 Hi, I tried new brushes. Still only getting 11.5 volts Quote Share this post Link to post Share on other sites
dubkicks 10 Posted February 1, 2013 Yep i have got one, I will check the amps for you pretty sure it is 90amp i will dig it out and get back to you today. I think it is machine polished aswell. cheers Kev. ---------- Post added at 8:28 AM ---------- Previous post was at 8:28 AM ---------- Quote Share this post Link to post Share on other sites
Yash 0 Posted February 1, 2013 Yep i have got one, I will check the amps for you pretty sure it is 90amp i will dig it out and get back to you today. I think it is machine polished aswell. cheers Kev. ---------- Post added at 8:28 AM ---------- Previous post was at 8:28 AM ---------- Sounds good. Quote Share this post Link to post Share on other sites
dubkicks 10 Posted February 1, 2013 Hi mate, Dug out the alternator but was unable to find the ampage. It is a standard 16v alternator and was in perfect working order when removed.The only reason it wasnt used was because it would not fit my 16v turbo conversion because of the S2 style inlet manifold i had fitted and i had to fit a mk3 golf gti one (what a ball ache that was). took some pics.[ATTACH=CONFIG]72007[/ATTACH][ATTACH=CONFIG]72008[/ATTACH][ATTACH=CONFIG]72009[/ATTACH] Hope this helps? cheers Kev Quote Share this post Link to post Share on other sites
