timthetinyhorse 0 Posted January 31, 2013 are the rear brakes the same across all models i.e. will a 16v or g60 caliper work on a vr6 or are they different sizes, i now the discs are different fitment but is there more too it? Quote Share this post Link to post Share on other sites
GlosterOx 0 Posted January 31, 2013 If you look at this: http://www.vwspares.co.uk/corrado_brakes.php it seems there was a change on rear calipers in 1993? Ian. Quote Share this post Link to post Share on other sites
Supercharged 2 Posted January 31, 2013 Pretty much the same... ABS cars have slightly wider pads and plus suspension uses 5 stud discs. Early cars used the MK2 type calipers with an external spring and late cars used the MK3 type - all used a 38mm piston so these can be mixed and matched although best not too. MK4 calipers are the way forward! Quote Share this post Link to post Share on other sites
timthetinyhorse 0 Posted January 31, 2013 so if i didn't go for the MK4 conversion mk3 calipers would also fit, bit tight for cash so looking for used calipers Quote Share this post Link to post Share on other sites
