Andy Brookes 0 Posted April 27, 2004 Hi All, Been to see a K reg VR6 tonight, as its early one it has a dizzy instead of coilpacks. Seems an advantage to begin with as no need to worry about those dodgy coilpacks going up the spout!! But does anyone know what other differences this engine has apart for the dizzy and if its worth holding out for a later car with the later spec engine?? Quote Share this post Link to post Share on other sites
dr_mat 0 Posted April 27, 2004 The later engine has the (theoretically) more reliable thin film MAF too, not just the coil pack, and all the other late electronics pack. (OBD2) Also, I think the coil pack gives more freedom to the ECU to control the spark timing. Correct me if I'm wrong but can the ECU control the timing on the distributor engine too? Quote Share this post Link to post Share on other sites
Andy Brookes 0 Posted April 28, 2004 Thought that may have been the changeover to OB2, what does that mean as far as what vag-com cannot monitor? Thanks for the reply Matt Quote Share this post Link to post Share on other sites
dazzyvr6 0 Posted April 28, 2004 my 93 vr6 has a coilpack and has the obd1 connector as far as i know Quote Share this post Link to post Share on other sites
dr_mat 0 Posted April 28, 2004 All the Corrado VRs use the OBD1 protocol, but the very late ones had the OBD2 wiring loom, or so I've been told. On the Golf the OBD2 engine came with a fly-by-wire throttle body, I'm led to believe. I can't really offer any more info on the pros/cons of coilpack vs dizzy tho.. (Mind you, given that the dizzy is not cheap either, you may be better off looking at other aspects of the car than things such as that.) Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted April 28, 2004 All VR6s are OBD1, whether they have the 2+2 connector or the OBD2 connector. There never was an OBD2 Corrado....... The only difference between the dizzy engine and the CP engine is the ingition and the intake boot material (rubber instead of plastic). The earlier engine just uses a dizzy and hall sender instead of coilpack and cam poistion sensor. K Quote Share this post Link to post Share on other sites
PhatVR6 0 Posted April 28, 2004 You can get an OBD2 ABV lump, but only in a golf syncro, not a corrado. Quote Share this post Link to post Share on other sites
dr_mat 0 Posted April 28, 2004 Ok, I stand corrected.. :) The later VRs definitely used the later, OBD2-style MAF and connector, however.. Or am I making that up too? ;) Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted April 28, 2004 Ok, I stand corrected.. :) The later VRs definitely used the later, OBD2-style MAF and connector, however.. Or am I making that up too? ;) Yep, that's true and unfortunately the only thing about VR6s that is OBD2 compliant! The idea behind OBD was the same as SCART, i.e. one connector suits all......looks like they've finally settled on the oblong OBD2 connector then as my mate's subaru and another mate's Cupra R sport the same connectors....... haven't tried VAG-COM on them yet, although I should for a laugh! K Quote Share this post Link to post Share on other sites
dr_mat 0 Posted April 28, 2004 It'll work, kev. In fact, the missus' peugeot 206 has an OBD2 connector aswell. It's a standard protocol, so *any* reader can talk to it, but it simply won't understand what the codes mean. The "pro" readers are just ruggedised mini-PCs with plug-in memory cards that hold all the e.g. VW error codes. If you want to work on a Peugeot you should buy the memory card with all the Pug error codes on it, and so on.. #include Quote Share this post Link to post Share on other sites
PhatVR6 0 Posted April 28, 2004 AAARGGHH!! you said "caveat"!!!!! I f*cking hate that words, all the arseholes in the office who think they are imprtant use that word far too much... Quote Share this post Link to post Share on other sites
dr_mat 0 Posted April 28, 2004 I also say "procrastinate", "anthropomorphic" and "perspicacity" amongst others. Go on, I can feel the waves of hate washing over me. Let it all out... ;) What I don't say are words like: "synergy", "team-building", "pro-active", "engender". My hair is not pointy. Hmm. Is it just me or did we turn this poor guy's thread into the "Matt, Kev and Phat Show"? /me shuts up.. ;) Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted April 28, 2004 AAARGGHH!! you said "caveat"!!!!! I f*cking hate that words, all the arseholes in the office who think they are imprtant use that word far too much... LOL, funny you should say that cause when I flogged my old Bimmer to someone at work, he emailed me and said "Subject to a final Caveat I'd like to buy your car". Arrghhh..... what a pompus muppet I thought, you don't deserve this car.... Quote Share this post Link to post Share on other sites
A5 VRX 0 Posted May 8, 2010 Thread re-erection! So there is no disadvantages then for a dizzy VR6 against a coilpacked one? Or am i just thinking to deeply about this? Thanks Adam Quote Share this post Link to post Share on other sites
