nia573 0 Posted February 10, 2013 Draper 78772 2 in 1 Soldering Iron and Gas Torch Handy little gas soldering iron This free standing torch features instant electronic ignition, adjustable flame control, on/off gas switch, and a refillable tank. Soldering tip can also be used as a hot knife. One fill of standard butane lighter fuel will give up to 50 minutes (approx.) continuous work. Display packed.. Item is unused & in sealed packet £25 posted 2nd class recorded Ratchet ½” Impact gun £22 posted Air Drill £20 Posted 1/2” dr Air Ratchet Wrench £21 Posted Air Chisel Set £20 Posted Laser TS Bits (5 Sided) 1/4"D 7pc (3389) This tamperproof bit set is supplied complete with socket rail and includes: TS10 TS15 TS20 TS25 TS27 TS30 TS40 £10 posted Draper Expert 8 piece 1/2" square drive TX-STAR bit set Contents: • bit holder 10mm x 1/2" sq. drive • 6 Draper TX-STAR bits: T20, T25, T30, T40, T45 and T50 x 30mm long • 1 Draper TX-STAR bit: T55 x 75mm long £8.50 posted 2 Ton hand power puller Unused but box is scruffy Heavy so £20 posted Ill post the lighter items 2nd class recorded & heavier air tools by standard parcels with proof of posting Mike Bangor N Wales mike@mroberts99.fsnet.co.uk Quote Share this post Link to post Share on other sites
iamsilverfox 10 Posted February 16, 2013 do a deal on the air drill and 1/4 torx bits? Quote Share this post Link to post Share on other sites
