CIPO 0 Posted April 30, 2004 Me again about the lupo wipers. They need the part numbers cause the wipers changed depending on the year of the car. Also, now they only come apparently with the blade and arm together. Good money making operation!!! If i can't get em at a good price in Belfast, anybody know contact number and price of where you got them. Cheers. Quote Share this post Link to post Share on other sites
aposegil 0 Posted April 30, 2004 Try GPC in luton 01582728892 Quote Share this post Link to post Share on other sites
dazzyvr6 0 Posted April 30, 2004 1x V6X2 998 406 1x V6X2 998 405 not sure but ive heard they are dealer only parts Quote Share this post Link to post Share on other sites
Supercharged 2 Posted April 30, 2004 You need 2 of V6x2 998 406 which is an arm and blade, GPC can get them but no cheaper than the dealer, mine were £33 Quote Share this post Link to post Share on other sites
Eug 0 Posted June 28, 2004 You need 2 of V6x2 998 406 which is an arm and blade, GPC can get them but no cheaper than the dealer, mine were £33 Ok before I buy anything ... do you have to replace the arm as well as the blade, or do you leave the Corrado arms and put Lupo blades on ? Quote Share this post Link to post Share on other sites
dinkus 10 Posted June 28, 2004 Er it's the arm you want to replace, you can then use either Lupo blades or Corrado ones (you need to drill one of the holes out to do it). Have a look at http://the-corrado.net/.archive/forum/viewtopic. ... &start=260 Quote Share this post Link to post Share on other sites
kieron 0 Posted June 28, 2004 You must replace the arm and the blade. The new blades will not fit on the existing Corrado arms. At least they didn't unless they'e changed the design in the 2 years since I installed mine. A tip that could save your windscreen.... When fitting the arms place a blanket over your windscreen as you just might catch the arm and without a blade it could take a chunk out of the windscreen. Or as in my case my hand which heroically threw itself between the arm and screen to save the screen. :shock: You could do it with the blade on but I found it bloody awkward. Another tip: When fitting the new arms use masking tape to mark where the existing blade sit as this will make installation of the new arms a lot easier. Quote Share this post Link to post Share on other sites
