Yandards
G60 CNC Cylinder Head
I am selling a CNC Heads G60 standard valve, full info on the performance gains can be found here: CNC G60 Head
I bought this to go on my nugget G60 but when fitted discovered a little too much had been removed from the head height and the valve would not fully close causing no compression.
This could have been easily rectified by either re-grinding the camshaft to suit or having the valve stems milled down slightly, as I was 500 miles from home at the time and needed the car in a running condition on the following day to go back on my course.
Given that this head currently needs a friendly machine shop to get it working I am looking for less than half what it would cost you exclusive of VAT for the whole thing, £250 plus the postage.
No photos handy but strangely enough it looks like a cylinder head.
Please note that you will see a reduction in boost pressure when running this head on a G60 as it will give a large increase in flow, which means more power.
