JonnyG60
G60 sump removal, water pipe in the way??
Trying to remove the sump on my G60, I have taken out all the bolts including the 2 gearbox end ones. Upon trying to work it off at every conceivable angle, it seems the bottom metal water pipe is in the way. Do people drain coolant and remove this to get the sump off?
Thanks
It seems the answer was yes.
I've searched around and don't want to start another thread, so is it okay to remove the plastic oil pump baffle and fit a windage tray with the standard sump? Or will this mean there are no baffles or anything keeping oil around the pump pickup?
Thanks
