timthetinyhorse
Lambda sensor....which one?
I need to get a new lambda sensor for the VR6 as when removing the cat the wires got damaged very close to the sensor (too close to remake them to any sort of standard) but my question is this....
Which one do I need, euro car parts list 8 ranging from £105 - £60, these are all listed for my car so what do I go for? Some don't come with the plug on so I presume I just match the colours up and solder the join?
Would love a little advice on this as I'm baffled!
Cheers
Rob
Would completely avoid the sensors that you solder the wires,try & get a Bosch sensor ,they may not be the cheapest but they are the best
I would contact TPS and give them your reg/chassis number and ask them for the part number then if you want to buy it cheaper from euro etc they can order the one you need via the part number. I would give you the part number but mine is an obd2 lambda.
