daniboy1_2_3 0 Posted April 6, 2013 Hi there im changing a wheel bearing on my 1995 VR6 today but dont have access to any torque values. I need the hub carrier to strut, lower ball joint nut, caliper mounting bolts, track rod nut, anti-roll bar tie rod bolt and driveshaft nut settings if anyone could help please. Quote Share this post Link to post Share on other sites
lewvw 10 Posted April 6, 2013 Strut to hub nut/bolt 95nm, caliper carrier 125nm, track rod nut 35nm, driveshaft nut 90nm + 45 degrees, ball joint nut 45nm (3 bolts are 35nm) , antiroll bar 25nm. Quote Share this post Link to post Share on other sites
daniboy1_2_3 0 Posted April 6, 2013 Thanks very much! Started to take one side apart until i was informed that when there is load on a wheel bearing it becomes even noisier, i thought it was the other was around. So now have to do the same again on the other side. One thing i did notice was the driveshaft didnt want to come out of the hub carrier. Is this a common problem?. Quote Share this post Link to post Share on other sites
