Jamie 1 Posted April 6, 2013 Ok just finished putting the radiator in my car and now I'be got the oil pressure light and buzzer on - what have I done??? I put a new pressure switch in last week to cure an oil leak and it was fine but could it be as simple as a duff switch? Also, since I've put it all back together every time I switch off the ignition the clock goes out and back to 0:00 and the trip goes to 0.0. It's got to be a disturbed loom somewhere surely? I did spill a bit of water over near the battery (well quite a bit actually) when I was filling the rad but I mopped it all up as best I could - could this be causing it? Quote Share this post Link to post Share on other sites
Supercharged 2 Posted April 6, 2013 Check fuses 16 and 21... I'd get a load of WD40 over the battery - if you did soak it i'd take it out and dry / re-wax the battery try as they are a rust spot! Quote Share this post Link to post Share on other sites
Jamie 1 Posted April 6, 2013 Nice one cheers SC. I'll check in the morning and have a bit more of a tidy up thanks mate :) Quote Share this post Link to post Share on other sites
Jamie 1 Posted April 7, 2013 Sorted - fuse 21 blown, wire to sender was damaged - new terminal and away we go :) Cheers Supercharged Quote Share this post Link to post Share on other sites
