Rams
Door micro switch issues
Hi all
Just got dash back in and connecting everything up however, the car alarm won't arm/work/disarm with the microswitch pushed in, as in sensing the door is closed.
Release switch or open door and alarm etc works as it should.
It's always worked so it must be my and my wiring but I'm stumped.
I do have one plug that's plastic covered with a pade style connector and this according to my multi meter is live, I can't see it should go anywhere? The immobiliser has a yellow wire with a normal spade connector and assume this goes to earth and meter shows no voltage.
Any ideas chaps what I have done wrong?
